I can't save my map as an image without cc3 crashing (and a few other issues(
Hi! I got CC3 a few days ago, and while I'm no expert, it's going pretty well however there's a few issues I've had and I was wondering if anyone could help?
- If I try to export an image to a jpg or png while using the 13th age style, CC3 just crashes. It works with every other style I've tried.
- The edit properties dialogue doesn't seem to come up most of the time when I click on it and then try to select something, like a landmass for instance. I've gotten it to come up a few times, but not a lot.
- Sometimes the... working area of the program seems to decrease every time I click on a menu item? This is fixed with a restart of the program but it's happened several times so I thought I'd mention it. Might be a bug? I'll screenshot it if it happens again to show you.
- I also wanted to know, is there a way to change what style you're using on a map after you've made it?
Overall, I do like the program a lot but there's a few hiccups which are a problem. Thank you for your time.
What operating system?
If Win 7 or 8, did you install as administrator (Not just an administrator account)?
Did you install the most recent patch available from your registration page?
It's windows 7, it's patched but I installed it normally not under administrator. Every single other map I've mad exports fine.
