Blends at map edges
I have contours that traverse the edge of the map, but the way contours are drawn makes any blends applied to show at the edge of the map. See attachment. How can I stop the blends at the edge of the map?
  • I've experienced similar problems. The way I worked around it was to draw the edge of the contour, fill or whatever else outside the edge of the map. Just far enough that the Edge Fade doesn't show at the map border with the effects turned on. I'm sure there's better ways to do this, but that was my quick fix.
