CC3 and FT Pro on Win8
I'm not sure if this is the proper place, so, if not, will an admin please move it to where it should be?
Anyway, I've finally managed to get some time to do some futzing around with CC3 and FT Pro, specifically, exporting FT Pro maps to CC3.
Unfortunately, it won't work. The saved FT Pro file is given the proper extension - .fcw - but CC3 refuses to open it, choosing, rather, to crash.
I have CC3 v3.11 and FT Pro v2.2.
Are these, perhaps, not compatible with a 64bit Win8 machine?
Thanx for any assistance!
  • TheElfTheElf Newcomer
    CC 3 is compatible for sure with Windows 8.
    But I think I use a different version of Fractal Terrains. In fact I just checked it, and yes, I use FT 3.
    But old FT saved .fcw files designed to work with CC2 Pro and not with CC3, and if I remember well there are some issues with that.
    I don't remember of the top of my head if FT Pro is compatible with Windows 8, but I suspect not, you'll probably want to look into upgrading to FT3.
    Otherwise, consider contacting ProFantasy technical support directly, they might now what what causes the problem, and if there is a workaround.
