Big Red X's On CA3 Example Characters
I noticed that several of the example characters for CA3 like the CA3 Barbarian and CA3 Burly Wizard have Big Red X's for the faces which indicates a .png is missing.
So can we get a fix for the numerous CA3 example characters and the missing .png(s)?
    It looks like some of the example characters still have symbol with a fixed bitmap path included. Guess I was a bit overeager in including old example (i.e. created during development) in the samples. This should affect mostly heads in the strong male characters,a nd you will only see it when you haven't installed in the default program folder on drive c. It also only affects sample characters, not the catalogs for new drawings.
    I've attached a zip file with the fixed characters. Please let me know if you come across other samples with red xs.
  • Jay_NOLAJay_NOLA Traveler
    edited December 2013
    Thanks,
    I found another one that isn't fixed in the CA3 Samples zip you provided.
    CA3 Ranger needs a fixed version.
    I have my CA3 installed in the default program folder on drive c also.
    At the risk of sounding like an idiot, which example CA3 characters are we talking about here? If I have CA3 (and I do), how would I check to see if I have the same issue? I don't see a barbarian or burly wizard on the CA3 Welcome screen/map.
    Thanks,
    They're talking about the example files in #examples/CA3 (Or thereabouts, I haven't installed CA3 on my tablet yet, so path is from memory)
  • VintyriVintyri Traveler
    Sorry, Ralf. You didn't get them all with your ZIP file. CA3Ranger.FCW still has an X where the face should be.
