Reinstal - New crashes
Greetings,
I've had and used this program as an an advanced newbie for a few years now. I recently decided to increase my skills and went through Sweeney's video tutorials without any problems.
A week ago I purchased the symbol sets (1,2,3) and the Tome of Ultimate mapping. I decided to uninstall everything so that I would be certain of my file directory structure. I then re-installed everything in the order suggested by the website (I believe) CC3,CC3update 10,CD3,DD3,SS1,SS2,SS3.
Now I can't even get through 5 minutes of Remy's Tome! When I go to place a mountain I get the "FCW32.exe has stopped working" error.
Should I just try to re-install everything again? Is there an error log I can view to get a hint of what's happening? Any other thoughts?
Thanks for your time.
I then installed the CD3 random city generator. Now whenever Try to access overland options, it crashes (FCW32.exe has encountered an error.) This occurs even if I try to generate a new overland map.
Is this a known problem?
Edit: I uninstalled CD3 and then re-installed it. Seems to be working ok.
Except for the fact that the random city command does not exist any longer, of course. Months back, before I got the symbol sets, i had used the random city generator successfully...
**sigh**
EDIT: I see the sticky regarding windows 7 and installation under Technical support. I think the information given elsewhere contradicts what is given certainly regarding the order of install.
I'm going to try the preferred order of installation given.
Good luck on the re-install!
What seemed to make the difference is now I have to make sure I open up CC3 as administrator (not just do the installs as admin). I never had to run CC3 as admin before, I just used to double click on a map and it would open up and I 'd be good to go. Now, If I do that, it'll hand and crash.
So I have to right click on CC3, run as admin, then Open file and select the map I want to work on.
EDIT: If I just double click on a map icon, then try to select a mountain symbol, it'll crash. If I run CC3 as admin, then open file it works fine. This crash is repeatable over and over.
I have been running three different maps at the same time recently, making Traveller sub-sector maps, while comparing them to the Sector maps.
Could it be related to the extra cores?
Forgot to mention my CC3 crashes ALOT!
I seem to have have had success with CC3. I no longer have to run the program itself as administrator, and can just click on maps to open them and everything seems to work fine.
I re-installed windows 7. And once again followed the install procedure outlined here: https://secure.profantasy.com/service/registry.asp
Thanks for your help!
On a side note. When I ran the CD3 high resolution bitmaps installation. There is an option to Repair and another one to Remove. I chose the Repair option.
Why would there even be a Remove option?
