Is there anyway to make an isometric hex grid in CC3? All I can find is isometric square grids and I really could use an isometric hex grid for my project.
Hmm.. While CC3 don't let you do this via the grid function, if you have Perspectives Pro installed, you can create a regular hex grid, then use the "3D Projection" [IPROJ] function on it (Make sure it is not on a frozen layer). Note that this should give you an isometric view of the grid itself, but there is no way to get an isometric snap grid to go with it however.
