Copy maps question
Going through the user manual and the TOUM3, I still not figure out how to copy and paste a portion of my map. I can see how TOUM is doing it, but it looks like it is set has a hotspot? in the program itself. Is that actually need to copy a portion of a map? Been looking around and can not figure this out. It seems like the instructions are missing a step or I'm misreading something.
Thanks
Viking
    No, a hot spot isn't needed to copy part of the map.
    What page of the TOUM are you on ?
    The copy command works like most commands in CC3.
    1. Select Edit -> Copy
    2. Select the entities you'd like to copy
    3. Right click, select Do it
    4. CC3 now prompts for clipboard origin. Unless you have something special in mind, the simplest is usually just to click somewhere in the center of your selection.
    5. Now go to the map you wish to paste into
    6. Select Edit -> Paste
    7. Click on the point in the map you wish top past the result.
    These are the instructions for basic copy and paste between maps in CC3. For more details on how to complete the creation of a local map from a regional map, continue following the tutorial in the tome.
    The reason we used a hotspot in the tome is that we wish to be able to make a link to the more detailed map as well.
  • Ok thanks for your help. Yea I just need to a basic copy.
