Art Pack 4: Books and Documents
248 ready-to-use .png art with support files
2.172 MEG
Usage: Licensed for personal or commercial use in finished maps or other artwork
http://rpg.drivethrustuff.com/product/117542/Art-Pack-4-Books-and-Documents-for-Dundjinni-Fractal-Mapper-or-CC3
The quality of a map is in the details you put in it. Add that level of detail to your maps with the huge amount of variation that Books and Documents gives you! Books either singly, on end or flat, open or closed, in stacks or lined up on shelves. Parchments and scrolls, bundles of letters, ink pots, quills and spilled splotches of ink. Even crumpled up letters and parchments to pile next to your desk's garbage can. This set contains a whopping 248 different pieces of art in .png format.
All art has been prescaled to 1" = 5' at 200 dpi, and all the necessary files have already been added to make this pack work for both Dundjinni and Fractal Mapper. This pack can also be used in CC3, but art will have to be imported into CC3 at the HI scale manually.
Art has been optimized to give the perfect amount of variation in each set. This will keep repetition from showing in your finished maps.
2.172 MEG
