CC3 dialog box placement problem
MonsenMonsen Administrator 🖼️ 81 images Cartographer
I was wondering if anyone know if it is possible to change the default position of the various dialogue boxes CC3 throws up. Right now, all the dialogue boxes shows up centred within CC3's window, which is kind of a big problem for me, since I run a dual-monitor set-up with CC3 stretched across both monitors. With the default placement of the dialogue boxes, they then appear with one half of the box on each monitor, making them difficult to read an use properly.
Some dialogues, like the new map wizard also makes a new dialogue box for each step, causing it to jump back to the centre for each step, making this particularly annoying.
It would have been nice if these could be centred on the drawing window instead, instead of the main CC3 application window.
An image showing the problem
  • 2 years later
  • I know this is a long-dead post, but... I have to second the inconvenience. Whenever I try to add text, the input box appears split across my monitors and I have to drag it out of the way. For that matter, dialog boxes appear above the map (even though I have an entire other screen to draw them on). This then forces a refresh, which can be slow and is always tedious.
