Annual Install order
I'm buying the Annuals in reverse order, no idea why, made sense at the time.
Well, I do know why. I didn't know what an annual was when I bought CC3.
So, I'm hoping this is a simple question.
Are there things in an annual that can/will be over-written by a later Annual?
Or hopefully, it doesn't matter what order I install the Annuals.
BoomerET
    The order in which you install the Annuals does not matter.
  • The reason I asked is because of the CA46 tutorials.
    I had been walking through 3 and 4 appendixes, because I didn't own the Annual. Well, after seeing the impressive work, I went ahead and bought it.
    Well, after I installed it, I still didn't have the icons that were supposed to be there.
    Then I found dungeon.zip(which contained dungeon.mnu) in the base dir, and thought it might have been possible that since I had modified dungeon.mnu for Appendix 3 from the tutorial, that it hadn't possibly forced an over-write.
    That or I failed to follow directions, which come on, I'm a guy, since when do I follow directions.
    TL:DR
    Everything is working for me from CA46 now.
    BoomerET
  • Posted By: BoomerETEverything is working for me from CA46 now.
    Cool!
    For anyone still having troubles with the CA46 icons see this excellent thread.
