Having Inserted Map Issues
I've inserted a map I want to use as a base from somewhere else but I'm having several problems, one being that the scale(mile) bar I put in the bottom right corner while I was in the New Drawing Wizard doesn't have the right miles marked on it for the size the inserted file turned out being, is there a way to rescale/put a new one in? Second problem, I couldn't scale the map border right and ended up deleting it instead, is there a way to make a new one?
