Cannot Load New Map
So, I just loaded my CC2 Pro on to my Windows 7 laptop, and while it looks like all is well, I cannot load a new map. It just keeps the opening image there - though I can use it like a map. Before I try to upgrade to CC3 I want to get this working properly. Does anyone know what the problem is? Also, my "Help" function doesn't work.
The reason for the help system not working is that CC Pro uses the old windows help format, which is no longer included in Windows 7. As for problems opening the map, I am not sure exactly, but try opening maps by double-clicking the map file in explorer instead of opening them from inside the program, maybe that will work as a workaround.
Cheers,
That said, I highly recommend upgrading to CC3 for working under Windows 7. As Monsen says CC2 is not supported anymore.
I am assuming the new CC3 is supported in Windows 7, so if I switch to that I won't have to do all the patching & work-arounds?
