Visual behavior of program itself is off a bit
Hello,
I have just gotten my Win8 machine due to a hardware failure of my other comp.
I just reinstalled my CC3 suite (in the order provided in your FAQ) using admin rights so, I think I installed everything properly and orderly.
The problem I am having is the graphics on each button like "symbol style toggle, symbol catalog settings etc..." are hanging off of the button and when I go to my catalog option and select two columns it only shows one still. If I select three it only show 2 etc..
I reinstalled the update just in case but, it didn't fix anything.
Additionally, the graphics are a bit fuzzy (not crisp) on the buttons.
I am running 1920X1080 resolution if that matters.
Any help or solution would be appreciated.
Brainburn
PS I took a screenshot and it is just too pixelated to really see the issue other than the showing 2 when in 3 columns.
Brainburn
Running same resolution as you.
I'll add some screenshots later, I don't have internet access on my PC right now.
The easy fix here is to set scaling to 100% (found in the display resolution dialog), but this will affect all text and many other items in Windows, so it might not be ideal for you. The other option is way more time consuming, and involves exporting all button images to external files, and modifying the menus to load these images instead of the built-in ones. Additionally, this last option will only fix the toolbars, and not the symbol catalog window.
Works like a charm.
Is there a way to set text scaling on a per program basis? I know you can with browsers...
Oh well. Awesome!
Hey thanks Monsen. I really appreciate the quick response.
Brainurn
