Floorplan windows with SS3 Modern
1st post
I have the modern symbol set which includes some lovely windows, problem is, whenever i place them they appear underneath the walls. I start a map and select floorplans and choose one of the bitmap options. Everything is fine, draw walls, place objects etc, but when i try to place a window it appears under the wall, unlike if i use DD and place windows.
What am i doing wrong, i have cosmographer too and that seems to work just fine. But is the instance above, the doors snap and work, but the windows snap and appear under the walls.
help!!!
    Check the sheet settings. Make sure the sheet order is correct. Also, use LIST in the windows to check if they end up on the sheet you expect them to. If they don't, check the setting for the catalog, or simply use the change properties command to change their sheet.
    Also, check the sheet for the walls, to make sure these are placed correctly as well.
