Traveller Sector Map issue
So I've just started playing around with the Traveller Sector Map template and I'm having an odd problem. My starport, base, and other such symbols are showing up as black on the map instead of white. I've tried manually setting the color on the upper-right toolbar and that doesn't work, and I've tried changing the properties of one object to set the color to white and that doesn't work. I'm not sure what else to try. I've been working on and off with CC3 for a while now, but I'd say my skill level is still well in the novice range, so I apologize if this is a simple question. But some advice would be appreciated. Thanks.
