CC3, DD3 and photoshop - help please! :)
OK...
I bought this program cause of our D&D group setup. We are gonna try something new and this is how it works...
I want to make the maps and then save them to a file and open them up in photoshop and create layers for all the creatures and players and put a fog of war over the top and display it thru a projector. So what i want to do is make the map, then have layers for each monster and trap and go ahead and set them all up where i want them. Then cover the whole thing with a black layer. I will have printouts of the map so i know where everything is. then as they move down the halls i will erase as we go....when they encounter monsters...i will be able to move them as normal thru layers.
OK....THE PROBLEM IS....
i cant figure out how to save the map to open in photoshop so it will show up in high quality when i zoom in.....all i can get is a huge map and when i zoom of course it pixalates and it all turns into big blobs when i zoom in in photoshop. SOOOOOOOOO.....how do i save my map so that my zoom is dynamic in photoshop like say a PDF or just so it will show up in high quality when i zoom in.
i hope i explained what i want well enough for one of you to help me
  • Ok known problem.. how to fix..
    Go to: View - Display Speed Settings.
    Click on Fixed Bitmap Quality: Very High
    Click on clear Bitmap Cache
    Tick Redaw on ok.
    Hit ok
    Zoom in on a section of your map.
    Export to Jpg like that.
    you should get a nice high pixel version that doesn't cause any problems.
    Don't know when PF is gonna fix that little 'issue'.
    Also make sure you set the export resolution sufficiently high. Raster images doesn't support unlimited zoom like a vector image program does, so if you need to be able to zoom far in, you need to export using a very large export resolution. (Settable through the options button in the save as dialog after selecting the correct export type)
  • I think you could create similar effects using CC3's built-in sheets and layers so you wouldn't have to export a jpg and do it all in photoshop. Just put all your layers in the order you want and hide them as needed.
    Then again, I haven't tried using "live" maps in my gaming yet, so your mileage may vary. =)
