Using GIMP with CC* Plans
Is there a tutorial for CC2/DD2 users for GIMP? I have been informed that what I want to do with my old CC2/DD2 plan can easily be done in GIMP. My question is HOW?
Discouraged but hopeful,
Sorpaw
Sorpaw
Note that you should be able to use any image editing program, so if you own another image editor and know how to use it, it is probably better than trying to learn GIMP.
I am assuming that you still want to color in the background of your map. If so, look for the filling tool (often called flood fill) to use. Note that it is important that you don't have any holes in your walls, or the fill will come through into your corridors. All editors have some kind of paintbrush tool you can use to fill any such holes however.
Note that after editing the image in GIMP or any other editor, there is no way to take it back into CC as a map file. You can insert it as a background image, and draw on top of it, but you won't be able to change anything from the image in CC.
Sorpaw
