SS3 "Modern" not showing up in New Drawing Wizard window
Hello I've watched tutorials on CC3 and I see that "Modern" is an option in a tutorial under the New Drawing Wizard choice window. I do not see it on mine (see attachment).
I've re-run the SS3 installation a couple of times now, running as administrator.
Does anyone have any advice for how to fix this please?
Thank you,
-Drake
  • Additionally, I can go into Symbol Catalogs, then select the path for some different templates, but I still think I'm missing something if I don't have "Modern" as an option to choose from on this screen. And like I said, I can see it that way in a tutorial video, so somehow it should be made available for me but it's not there.
    Thanks,
    -Drake
    You're not supposed to have any Modern option on that screen. That is the list of map types, not styles. If you choose overland Maps and click next, you will find the modern overland maps (Among the other types of overland maps), and floorplans will lead you to all floorplans, including the modern one (I believe these are mostly modern, because fantasy floorplans are under the dungeons type).
