Fractal Terrains observation and suggestion.
One thing I've noticed about FT's world generating is that brownian noise makes great land masses but horrible mountain ranges and ridged multi-fractal makes great mountain ranges but bad land masses. Is there any way to do a two stage generation where the land mass is generated by brownian noise but only up to a certain altitude then a ridged multi-fractal is generated then the two are merged with the ridged multi fractal going over the land mass when sea level or higher but then would go "under water" when bellow sea level.
I really think it would generate more realistic land masses and create the illusion of plate tectonics.
FT users fall into two camps: the "I need to recreate this exact world that I've had for forever and I want F to do all of the heavy lifting" and the "I want lots of plausible random worlds". The first camp wants the ability to be able to paint the world in broad strokes (continent here, mountains here, forests here, etc.) and have the system compute plausible results from their inputs. I have an approach that would work for this technique, but it's not terribly compatible with how FT likes to operate and takes a long itme to compute. The random worlds folks seem to be reasonably happy with FT, but they'd like more plausible details than the software generates now. Trying to find useful compromises between these two vocal groups is a tough task, so I often just do what I think will be fun. That sounds awful, but people seem to be able to put my new toys to use in each release (consider the Terraformer project; it was an effort by a user to elaborate on what was a simple toy that I put in on a whim).
If I were starting out to develop FT today that I would do things quite a bit differently. For example, I would store editing data differently (I'd use a pseudo-equal area projection to store data) and I would change the computation model (I'd make sure to take advantage of GPU computing). One thing that I can't do is break the last 15 years of people's work (it happened once with a timing-sensitive bug and I'm trying not to let that happen again).
