Somebody Help Me Please
Hi All i need some help. Ive messed up the scale on France, Spain and Italy (basically southern europe on my map) - see attached. I need some help to fix it and dont know how. The Europe, Asia and Africa are all one poly and it took a long time to create so i dont want start over :-(
auryx
1) make a backup copy before starting.....
2) use "split" to cut the poly on either side of the offending bit of coastline
3) use "list" to make sure the excised bit is now a separate path, then delete it
4) draw a new path you like better
5) use "combine paths" to join things back together
good luck
Peter
I tend to need to back up to an earlier version further back than undo can handle. Also, I may decide to go back 20 maps, and go off in another tangent.
@Moskva. When starting a map you have the option to add a grid.
On the fourth? widow there is a check box "Grid Overlay", check that.
And with the button "grid setting" you can define what kind of grid you want.
