CC3 crashes when trying to export a specific map
Today I went back to a project and did some fiddling about, mostly changing names of things. However, when I went to save the map as a PNG (a relatively small one as well) CC3 instantly crashed. Restarting the computer, saving in different formats, everything results in the exact same crash. Indeed the only thing that doesn't result in a crash is if I save it as a file 250 by 300 pixels across. As one might imagine that is a might irritating. Now, the thing is I've also tried saving other maps as PNGs and they work fine, which leads me to believe that it's something specifically wrong with this map file.
I've attached the file in the hopes that someone can corroborate that is is in fact a problem with the map itself and not something specific to my computer that is fouling things up. And if so, with any luck point me in the direction of fixing whatever is causing the problem.
Any help would be much appreciated.
As for the crash, I am unsure what to do about it. I have noticed that it helps to ensure that you have enough free physical memory when starting the export (in other words, not too much other stuff running at the same time), but other than that, I can't think of anything that would help.
If you have Vista or Win 7, they take up 1 to 1.5 gigs of memory to run. My computer has 3 gigs of meory and handles large maps fine. So if you have only 1 or 2 gigs of memory and Vista or Win 7, that is the problem. Your CC3 install should be okay.
