No Matching Draw Tool Error Message
Hi All
Very new to all this so please forgive me if I'm asking a silly question:
I have installed CC3, DD3, eTome and CDPro - have also installed the update for CC3 as mine was fairly old.
Now following the tutorial in eTome for City Designer but when I click on the contour button it tells me no matching draw tool found - can some clever soul tell me where I need to look!!
Many thanks
Jean
    edited August 2008
    This means that the map you are using doesn't have any draw tools in the appropriate style.
    Click the "All Map Drawing Tools" button, then select another style to the top left. For example "Default". Select a Drawing tool from the box, or it won't save your new choice. If you don't want to draw with the tool you selected here, just click ESC to cancel it. The contour button should now work (Provided you selected a style that has contours defined at all).
    You can also switch style from File -> Drawing Properties.
    Note that if you were using drawing tools from the previous selected style, you need to switch back afterward to make these available again.
