My first 'John Speed' map.
This has proven pretty educational. It took some doing, but I think it mostly turned out the way I wanted. Not bad for my first serious effort in CC3, I think.
You can see it here.
    Very nice map. Looking good.
    It is a good time for John Speed maps now, as they fit so nicely with the latest annual.
  • I agree, this is a wonderful map done in a style that i like very much. Good work.
    Pat
    Excellent work! I only believe you have the line width for where the walls meet the towers a little thick. I'd suggest using "Change Properties" on these to set the line width toa botu half the current value.
  • Posted By: RalfExcellent work! I only believe you have the line width for where the walls meet the towers a little thick. I'd suggest using "Change Properties" on these to set the line width toa botu half the current value.
    Yeah, I noticed that after the fact. I'm not sure what happened there, as I thought the width was quite small when I did them...so small in fact that I had to increase it. I'm wondering if that's a result of the effects on whatever sheet the sketch tools were applied. I'll have to fix those, 'cuz it's driving me nuts.
  • Nice - very well done!
    Posted By: WizarDru
    Could well be, if the sheet they are on has a strong black glow for example. But to say exactly, I'd have to see the CC3 file.
