convert.exe entry point not found exporting to png
Folks
While exporting to png, I'm getting the following error convert.exe entry point not found. Any suggestions for a fix?
Mel
Mel
As a workaround, you can export the map in .bmp format, since this format doesn't need to be run through convert.exe (unless you have antialiasing on), then manually convert it to .png afterwards.
still getting the procedure entry point NTArgvToUTF8 could not be located in the dynamic link library CORE_RL_magick.dll
It was exporting prior to adding the September 2012 annual installment
Hope this helps.
Thanks, that cured it!
Cheers
Mel
