Inserted file
SO I have the first file from FT3 inserted on its own sheet (altitude map). Now I have a second file that I want to do the same with Climate map). Here is what happens:
1)I start the insert at the bottom right corner
2) I start do drag the image with Ctrl pressed
3) The files starts to draw but, not in the corner
4) As I drag the corner of the image up to the top left corner the file does not line up with the frame in CC3
SO, is this a bug? or is there a reason this is happening.
