Cosmographer 3 Not Installing
I have purchased Cosmographer 3 and tried to install it onto my World Builder bundle but when I run the installer it wants to remove my installation or repair it. This is the first time I have ever tried to use this program so I don't know what is going on. Please help Cosmographer is the reason I brought the program.
  • I'm also getting the same issue when I try to install the Hi Definition texture pack bundled with the software too. It wants to modify my installation not add to it!
  • I had the same issues with other add ons. Here is what I did to get the install working.
    Check CC3 for 3.42 v ersion
    if not then run update from download section
    Run add on installer, select modify/repair
    re run update
    I have also had problems with the windows installer on xp not working. SO there are still some bug in the system. Though I did get the SS2 pack installed, finally, by copying the set up to the c drive.
    Good Luck
  • I'm already running 3.42.
    I'm going to try technical support as I was aiming to be using this program by now, especially after spending a small fortune on something that isn't working. So annoyed right now, thanks for trying.
  • This was fixed by removing and reinstalling the expansion as strange as it sounds. Even though it was never installed in the first place!?
    Thanks to a quick response from tech support!
