Breaking up a poly?
This is probably a common problem (maybe?) but I am trying to use break to clip out some parts of a multipoly. I drew a solid black box and now I am using multipoly to "carve" out the rooms. Problem is it is leaving lines between rooms in some spots. I am trying to break to make the "line" self contained and then erase it. However when I select break and then click on the area it just gives me the prompt "Command [BREAK]:" clicking.
Is there a method to break off a piece of a multipoly?
