DD3 Walls Question
I'm trying to connect a wall to an existing wall and running into a problem as depicted in the below links, am I supposed to do something to get a clean connection? I tried finding an answer in the Tome of Ultimate Mapping, but no dice.
-Right click the Explode button and select line to path.
-Follow the commands on the Command Line by selecting each entity that you want affected.
-Right click> Do It
Cheers,
trying to decide if I should invest in it
Cheers,
