Combining Paths
OK, I'll admit it. I'm a blithering idiot, but even worse, one who needs help with what is likely a really basic question.
I draw two or more paths that I would like to use as a river and its tributaries. To do so I'd like to combine these entities using the Combine Paths command (right click Explode, select Combine Paths). I click on Combine Paths, the cursor turns into the arrow with the tiny box at the point, "Select First Path" appears in bottom dialog box. I click on one of the paths I want to combine, Command (CMB): appears in dialog box, and NOTHING ELSE HAPPENS! The path doesn't turn grey, no dialog box appears, no message to select a second path, zip, nada, zilch, nothing. I'm literally back to having to select the Combine Paths command again.
What the heck am I missing???
    Usually, if you wanted to join two rivers, you'd just do another river and attach it to the end points of the sections you want to join. Let me know if you need help with this.
    Rivers are usually made from smooth lines (splines) A path is not a spline. It can't combine splines because it would alter the apearance of the adjoining nodes.
    One solution would be to do:
    Explode both the splines.
    Line to Path (select by Prior)
    You've now got two paths with lots of nodes.
    Then do Combine.
  • Well, we are getting closer as I was not aware that a river was not considered a path. Here the issue is that I outline my rivers and tribs (all colored light blue) in navy blue. All the rivers and tributaries that run into it need to be a single path or the outline shows up at the end points where the various tribs connect to the river.
    This is good info and a good start, but please comment if you have some further advice. Thanks.
    Just a little change to Simon's instructions:
    Don't explode the splines, do "Smooth to Straight" instead (right-click Explode button to access). It makes the splines into paths. Now do Combine. Then do Straight to Smooth, turning the combined path into a spline.
  • Gents,
    Thanks for the help. Still not as proficient as I want to be and don't even know if this is the best way to do what I want to do, but your answers were spot on. Now it all makes a bit more sense.
    Regards, Colonel Bill
    Posted By: RalfDon't explode the splines, do "Smooth to Straight" instead (right-click Explode button to access). It makes the splines into paths. Now do Combine. Then do Straight to Smooth, turning the combined path into a spline.
    I've been served! I'll leave it to the expert.
