Missing Bitmaps
I recently bought the CC3 world builder pack and have been messing around with DD3. I've discovered that the bitmap fill styles that I have available through the dialog boxes (the "Add room" box, for example) are only very low quality images. I've looked through my install directory and have discovered that the higher quality images do exist, but I don't know how to access them through the program. How do I get these options into the selection drop-down menus where they belong?
    There a several possible reasons/solutions for this
    - Make sure that you are actually using a DD3 template . the CC3 dungeon templates have only limited resolution fills.
    - the Program might only show you a low resolution fill to save memory. Right-click the Display Speed button and choose a fixed bitmap quality of very high.
    - to add the DD3 bitmap fills to an existing map, do Draw > Insert File and insert CC3/System/Fill Styles/DD3 Dungeon Color. FCW into your map. Delete it again right away. This will add the fill styles to your map.
    Hope this helps.
  • Thanks for the help. It turns out I wasn't using a DD3 template. I could have sworn that those options weren't there when I created the drawing, but perhaps I just overlooked them.
