Demystify move object (and selecting things in general) please
Hello all!
I've had this sort of ongoing problem with CC3 that I'm hoping one of you fine folks can help me solve. On my map I have a forest (using the Default Terrain tool, on the Land Features sheet, Vegetation layer). Sitting on top of that is a text object with the name of the forest (using the Text tool, on the Text sheet, Structures layer). I want to move the text a bit, so I select the Move, Scale, Rotate tool. When I do the command line changes to Select Entities. The problem comes in with trying to select the text. No matter where I click, all I can select are forest objects in the forest. Even if I manually select the Text sheet and Structures layer as the current sheet and layer, I still can't select the text to move. I even tried zooming in so the text object is gigantic on my screen, but no luck there either.
In general, I've also been having problems when it comes to selecting things for the various tools in CC3. Sometimes when I select a tool it wants me to single click on an object to select it, sometimes it wants me to click on opposite corners to draw a selection box. I can't figure out a pattern as to what triggers CC3 to ask for the single click vs. the selection box.
Any help on either of these issues would be greatly, greatly appreciated.
CNYGamer
CNYGamer
Type drag and then select the text's lower edge. Right click and select 'do it'.
Then click on the bottom edge of the text and then move your mouse pointer to where you want it.
Or you can type list
Then click on the text.
A window will come up tell you all the items you listed.
Write down the tag number for the text.
You can then move by tag number. I forget the details on that, but someone will chime in or it is in the help file.
Freezing layers helps many times when you move things.
The two exceptions to this is:
- Text: text always needs to be selected by clicking on it's baseline.
- Lines with width: Lines that have a width setting needs to be selected by clicking on the actual line, which goes through the exact center of the entity, no matter the width. An example on this is your typical dungeon wall or road.
CNYGamer
