Memory problems with fractalize
Hi. I'm constructing a large world map (12,000 x 10,000 miles) which has a thin ridge of continents abutting all sides of the map border; a ring of ocean inside of that; two semi-circular landmasses inside of that; another ring of ocean, and then two main continents (roughly 2-3000 miles each).
The default land mass fractalizes based on a percentage of your landmass size, so if i use default setting, i end up with relatively long, unsightly straight edges to my continents. When I changed the fractilization settings I think I ended up with so many nodes that it slowed CC3 to a crawl and crashed the program a couple of times. (I have a P4, 2.6 GhZ (NO dual or quad processor), with 3GB RAM).
Any recommendations as to how to get reasonably fractalized borders (what settings to use or other parameters to play with) that won't crush my system?
Thanks,
Mosk the Scribe (who needs to finish making his map!)
Thanks,
But I think using fractalize as 10 percent strength should be okay.
I created several strengths, and did a save on them in CC3. So I have settings for 5, 10, 20 percent.
I'm guessing the memory usage problem has to do with the minimal length setting (under advanced properties for creating default land mass as opposed to the actual fractalize command with the straight line and squiggly bar at the left side of the screen in tool bar). Not sure if anyone's found useful settings for a large map for minimum and maximum length; % strength; minimum strength; and depth - I've played with the parameters a bit but my trial and error method doesn't seem so efficient.
Thanks for any input,
Mosk
Thanks for the advice. I'll give your method a try tonight or tomorrow morning and post back on whether or not it resolved the issue.
Mosk
Use that to draw what the continent looks like, bays, fjords, bays, then fractalize the cntinent once or twoce with a strength of 10-20. Then do the next continent.
Jim, I'll try out your method on my interior continents.
Thanks to you both for offering some solutions.
Mosk
