Regional map South West Ashara desert
Had some extra time and decided to make a small map.
The map isn't finished yet but I wanted to show :-)
Comments and suggestions are welcome.
@Mateus090985
Glad you like the map.
Reality isn't the most important aspect. But when you look at the north coast of Africa you see that it gets quite close to the Mediterranean sea.
You are right about about the glow in the rivers. Was experimenting with effects and forgot to remove them.
The sea is actually much more blue when seen in the original map and when printed. Its the conversion to a jpeg that makes it kinda purple.
Allthough there is a bit of trading, the desert nomads aren't to frienly and on a regular basis raid caravans, cities and each other
Thats where the Tor's come in. They are the fortified towns/cities that guard the rest of the land.
Tor Bogal is in a moor, hence the green color.
The effects used are the default effects for this style pack (annual 26).
For now I have no intentions in using other effects.
