Can't change sheet/layer
I used the Default Terrain option and drew a polygon on my map. I had the wrong terrain type selected (it was forest, which isn't what I wanted). So I used the Change Properties option to change the fill from forest to mountain.
The problem I'm running into is that when I originally drew the terrain as forest it assigned it to the Forest sheet, Vegetation layer. Now it's covering up some mountain pieces I put over the terrain. So I selected it again using Change Properties and changed the sheet to Terrain and the layer to Minerals/Mountains (and made sure the check boxes were checked) and clicked "ok". The problem is that it isn't making the change. The terrain feature is remaining on the Forest sheet, Vegetation layer.
If anybody has any clue as to how I can overcome this I would be grateful.
CNYGamer
CNYGamer
Keep Calm
and
Map On
It turns out that the situation is resolved. I actually just started a whole new map and things are behaving as expected. When I created the map on which I was having trouble I selected the SS1 Fantasy Color map style. I wonder if there is something with that style that causes the erratic behavior because I was having all kinds of issues with commands not behaving as expected then I created a new map using CC3 standard overland style and everything seems to be working.
Oh well, maybe it was just one of those things.
CNYGamer
Then again, it might be something else going on. As Ralf suggests, if you post the map, we are likely to see very quickly what's going on.
Steve
