Fractal Terrains: Unusually dry worlds
When generating a new world using FT pro, what should I set the rainfall amount at? using the default settings, I get worlds in which all the tropical areas are covered in dry grasslands and tropical deciduous forest (which is also associated with dry climates).
How do I go about getting a world with jungles like SE Asia and the Amazon?
    I'm no good with FT, so I don't know the best value, but you can use Global Raise/Lower -> Rainfall, and the climate types should change. Just increase it slowly till you get what you need.
    You can also use the Paint Raise/Lower functions to increase rainfall in areas
