John Speed City Map
This map is baed on the 07 Annual. Feedback welcome.
  • Wow, I really like it! That is great map. How long did it take you to make it?
  • ModricModric Traveler
    Took a couple of hours last night. I needed to practice making the walls first, which were tricky.
    Wonderful! I get to see too few cities in the John Speed style. ;) Good job working with the walls, they are indeed a bit tricky. Creating workable symbols for the large number of angles was quite a challenge at the time.
  • edited January 2012
    Here is my attempt at a John Speed village. I'm using this style, just this one so far, as 'ancient towns and villages'. With the default city symbols as recent locales.
    nik.PNG 51.9K
    Nice work, Jim. The only thing that's a bit jarring is that some houses are rotated out of their "normal" alignment. For this style, you need to switch the next symbol in the "rotation sequence", not rotate the symbol itself. Also, switching on your sheet effects would make it look nicer.
  • Didn't realize I did the rotation thing, I'll check into that.
  • On the original maps, the perspective isn't always perfect on the buildings. So I've always felt free to rotate occasional symbols a little bit (a few degrees) if I needed to. In some cases it can actually make the map look closer to the style, with fewer repeated symbols. Just make sure you're only rotating a few degrees -- too much, and it really looks off.
    Steve
