Ground texture question
I have been trying to do a fantasy map with DD3. I would like to know how can I get ground textures like the ones you see on www.profantasy.com, on the scroll down menu to see the maps. The miniature battle map.
Thanks
Thanks
Do note that a battle map is pretty far zoomed in, which can make the fill style appear pretty different from viewing it on a zoomed out 1000x800 dungeon for example.
The map itself is from the September 2008 Annual, but as stated, the background fill style is available even without this.
Thanks for you reply/help.
Toby
To force CC3 to use a specific resolution, Click Display Speed settings
This is what you have templates for. If you ever need to make a change that should appear in all new maps, change the template instead, either by modifying the original, or by creating your own copy of it and modifying that.
