Fractal Terrains 3 and AstroSynthesis 3
Hi all,
I own both products (FT3, updated to 3.09, and AS3) and I noticed FT crashes when called from AS3.
I supposed FT Update 3.09 corrected this compatibility issue, but only one thing changed: I was used to seeing FT crash when called to display and edit a planet surface from AS3; now planet display is done well. But surface edition still leads to FT crash... The point is that AS3 does not propose to save parameters thus I can't ask FT to produce equivalent map I can edit and import later in AS3.
Some information about this issue?
Best regards,
Paul
