inserting maps, crash after certain number
JimP
🖼️ 280 images Departed Legend - Rest in Peace
I came up with a 10x10 template that holds 100 180x234 mile surface maps.
I was able to insert 96 of the maps into the template. I insert one more, program asks if I want to close or look for a solution online and close.
It could be that I have fractalized too much on some of the maps I'm inserting.
Attached is the map with 96 inserted maps and 3 additional maps I've tried to insert.
I can always make the template 9 columns wide if necessary.
Thanks !
The reason I'm doing this is to add an editable map to the FT3 southern hemisphere add-on I made.
My original Crestar was a small part of the southern hemisphere. All of these map making things will combine into one large planet with both south and north hemispheres.
