FractalTerrains and automation
Hi,
[p]I own Fractal Terrains and I played for a while with excellent Terraformer "plugin" ! The combination is powerfull and dramatically improve my planets surface realism
[/p]
[p]But I'm wondering if a way exists to automate the generation. I mean: I want to produce a hundred worlds at a time, manipulating their climates and properties for each instance. For example, I'm asking myself if it is possible for rendering a ice world to create a batch file (command line) that may look like:[/p]
[p]Is it possible ?[/p]
[p](the goal is to make both FT and Astrosynthesis to work together to create entire galaxy...)[/p]
[p]Thanks![/p]
Anorr
ft.exe -color=ICE001 -param=xxx -layer0=CLOUD001
[p]Thanks![/p]
Anorr
For now, I just want the maps generated with some color/texture settings, maybe a fixed fractal randomiser, but no more. When it comes to have an interresting planet, then I would surely manually modify it
Regards,
Thanks Joe! I did not know about that PDF!!!
Thanks again!
Paul
