Having a problem with DD3 printing effects
I just purchased the DD3 add-on (great set of products by the way) Woring on a small dungeon just to get my feet wet. When I try to print with settings on, CC3 crashes. However, I can re-load same map and try printing without sheet effects on. Map prints just fine. Anyone have any idea why? Thanks in advance for any help.
Chris
    Crashes can be due to low memory, as effects consume a lot more resources when on. Have you tried closing other programs and tried the print again? Have you tried exporting the map to an image file with effects on. Does this work better?
  • Thanks for the reply. I am using CC3 through Parallels 6 as I am a Mac user. Maps made from CC3 and CD3 print fine with settings on. It's just the DD3 maps that cause problems with settings.
    I can also save to bmp and print everything fine. Except for my DD3 maps, the purpose is to use them for battle mats in a D&D game. Therefore the grid of 5' is important. Unfortunately, I can't figure out how to print bmp or other image files in the v=correct size to keep grid spacing correct. If there is a way, I'd love to hear it.
    Thanks again,
    Chris
