Cannot Draw Roads below a certain point
Hi all,
Drawing my first town map at the moment and have run into a curious problem.
I cannot draw roads below a certain point on the map. I have drawn roads on the lower portion before but now every time I select the first point in a road it matches on the x-axis but if I am below a certain latitude it just puts the point at that higher "threshold" latitude.
Any idea what could be causing this?
Edit: Ah nevermind, you have some houses put on the map border layer I think, which makes the program think the border is further north/up than it should be.
Select the map border layer and click "hide all" and you'll see. Change them to another layer and it fixes the problem. (Or you can delete those buildings and place them on the map again).
