Contours not showing properly
contours are not showing properly on my map, following the tutorial, the contours are always below the LAND sheet. even if I put it at the top. This goes with the river, the river is on the tree while the symbols sheet is on top. I can give you additional information. Can you guys help me? >.<
    Are you sure you are arranging your sheets correctly?
    Remember that the order sheets are listed in are the order sheets are drawn on the screen, so for the trees to show on top of your river, the SYMBOLS sheet must be below the RIVERS sheet in the list (The sheets at the bottom of the list is the one that will appear on top of everything else in the map)
    Also make sure that your symbols are at the sheets you believe them to be. Use Info -> List to check the entities and check which sheet they are on.
    If this doesn't help you, please post the .fcw file for your map (or a simple example showing the same problems), so we can look at it. It is easier to give correct advice that way.
    land sheet
    river sheet
    symbols sheet
    I made the same mistake when I started using sheets.
