Square fill line not solid
Hi all
I wonder if you can help me.
I want to fill a multi poly with a 5' square fill, but instead of getting solid lines I get dashed lines. I've made the square fill by using a 10' fill and adapting the settings to 5', 5', and scale to .5. The size is right but the image below shows you what I am getting instead of solid lines. See below this is a 25 x 50 map with the grid set to 5', but as you can see I don't get solid lines.
The thing is I haven't selected square lines, so I am not sure why this is doing this?
My second question is a little easier. I thought I'd scaled my map correctly but when I go to print it as scaled 1"=5' I instead get a fraction like 0.89 = 4.345 etc. Those aren't the exact numbers but I get its approximation, which suggests my scale isn't quite right, even though I thought I had done a non visual scale and got it right?
Can anyone help.
Thanks again
Ab
Can anyone help.
Thanks again
Ab
Ab
thanks
Ab
Open the Symbol Manager and click the "Show fill style symbols" option. Locate the symbol "Square fill" and edit it. Use "Change Line Style" to turn the lines to "Solid". That's all. You can do the same to the hex fill symbol, if you want.
Ciao,
Ralf
Would never have known/thought about this. Thanks for the prompt response
Ab
