Viewer Issue
I am working on a map using Jon Roberts Overland style. I cannot get the full map to open in the Viewer. The Viewer works fine on other, default styles, but not on the Jon Roberts style. Is this an issue with the elements in the Roberts style, or am I missing something in the Viewer?
Thanks,
Don
    edited June 2011
    This style utilizes raster artwork which is not available to the viewer. Right now, the only raster artwork available to the viewer is the base CC3 artwork, and DD3, SS1 and SS2 artwork can be downloaded separately for the viewer. Anything else won't work in the viewer. (See the viewer download page).
    Currently, your best option for making this map available to others is to export it to an image file, or print it to a pdf file (requires a pdf printer to be installed)
    By copying the missing images over into the same folder as that in the viewer, you should be able to see them. List an entity which displays as an X to find where they are all stored.
  • Thanks for the help, Monsen and Simon! I appreciate you taking the time.
    I will be sharing this map with several folks, none of whom have access to the images and symbols from the style sheet. For that purpose, I think I will have to send it out as an image. I will do like you suggest, Simon, on my own laptop, for when I use the laptop to show the map.
    Thanks,
    Don
  • Any chance Profantasy will update the viewer to handle this issue?
    We'll certainly look at adding more working bitmap styles to the viewer. Can't say when though, sorry.
