How to easy resize symols on the map?
I beginer in CC3. I have question. How to easy resize some of the symbols (house, trees etc.) on the map. Answer inside help topic isn't enought. It don't work.
    Hi there and welcome to the forums.
    There are several options to resize symbols:
    1. During placement, you can hold down the CTRL key and move the the mouse up and down to scale the symbol dynamically.
    2. During placement, you can also right-click and type in a scale factor for exact numerical values (e.g. factor 2 for a symbols twice the size).
    3. After placment, you can use the SCALE command (on the left toolbar) to resize anything, including symbols.
    4. After placement, from the menu you can use Symbols > Scale Symbols in Map to scale any symbols in the map without moving the point of origin.
    Is any of this giving you problems?
