How to connect roads without overlapping outlines
Hi,
I am just beginning to use CC3, so this is probably a silly newbie question. However, I couldn't find an answer to my simple problem yet.
I am drawing a system of roads (streets) with intersections and crossroads. I use a road type of 3 units width. As the roads meet or cross, the outlines overlap which does not look good (see attached drawing). I guess there must be an easy way to "merge" the roads so that the overlapping is not visible.
Any hint would be appreciated. Thank you in advance.
Wolf.
Wolf.
Also, you could draw the town/city secondary roads in brown. And then draw the main roads in a gray or cobblestone look and put the main roads crossing over the top of the secondary roads.
