Wall Cutter
I added rooms and corridors to a map and was able to use the wall cutter to remove the walls. I added a couple more rooms and then tried to use the wall cutter to remove the entries to the corridors and it removed all the rooms wall except the place that I wanted the wall removed. I am not sure if I changed a setting that makes the cutter remove everything but what I click on or something. This was very frustrating and it was working very well and now I am at a standstill till I can figure out how to do this right. Any help would be greatly appreciated.
Thanks,
Guildmaster
adventures-guild.com
  • It seems to only happen when I am trying to cut the wall on the corner of a room. Is there a way to do this to get it to work the right way?
    The wall cutter might not work correctly in a room corner. To cut a wall without using the cutter symbol, you can...
    - freeze all layers but the Wall layer
    - enable the grid (if you want to do an exact break)
    - Use the Break command (on the lower left toolbar) to break the correct space into your wall.
    If this still doesn't work, you should check that
    - the wall isn't on a wrong layer
    - that you don't have a double-wall at that point
    Hope that helps.
