Changing Dungeon Geomorph Colors
I am trying to figure out how to change the Dungeon Geomorph colors to something different. However, it keeps posting it as a white floor. I don't know how to change the color to it.
Also, how do I change the pattern?
  • Razzle,
    No expert here, but i normally select the "Change Properties" (just to the right of the erase function) and then select the item i want and hit "do it". That will bring up the properties box. Select the "Fill Style" and then go through the list to find the type of fill you are looking for. You can also select the color from that same menu panel.
    Probably tons of people that know an easier way, but that is what i have done.
    Good luck!
