Map Canvas is Blank
Not sure what I did after pressing the zoom extents button my map canvas is now blank - white, cannot draw anything or place any symbols.
The cursor location shows NAN,NAN and any of the Info commands return NAN. when I view the map in the open dialog it displays the preview just fine.
Any thoughts?
Any thoughts?
filename01_001, make changes, filename01_002, etc. until I complete what I map trying to do. This makes it easier to back up to an earlier version. Undo doesn't always go back far enough for me, so I came up with this method.
Cheers,
You might have white text or a white symbol way off on one side.
The zoom extents, to show everything like it wants to, shrinks the map.
Hide one layer. Then zoom extents again. Keep doing this until your map shows up. Save to a different filename.
Then using erase, delete everything outside the map.
Zoom extents with all layers showing.
You should now have your map back.
